查看: 1683|回复: 0
4321s/4421s F.09版BIOS解决IDE模式运行慢问题
发表于 2011-3-13 13:49:15 | 显示全部楼层 |阅读模式
TITLE:
HP Notebook System BIOS Update (ROM Family 68AHH)
VERSION:
F.09
DESCRIPTION:
This package creates files that contain an image of the System BIOS (ROM) for
the supported notebook models with a 68AHH Family ROM. This package is used to
flash the System ROM on supported notebooks that are running a supported
operating system.
This package includes the following methods for updating the BIOS version:
- Use the HPQFlash Utility to update the BIOS directly in a Microsoft Windows
Operating System environment.
- Create a bootable USB key to update the system BIOS.
- Use HP System Software Manager (SSM) to update the system BIOS on target PCs
in a network.
NOTE: To determine the ROM family and ROM date, press F10 on the target
notebook during startup to run the Setup Utility, and then view File/System
Information.
EFFECTIVE DATE:
June 29, 2010
CATEGORY:
BIOS
SSM SUPPORTED:
YES
PRODUCT TYPE(S):
Notebooks
HARDWARE PRODUCT MODEL(S):
HP ProBook 4320s Notebook PC
HP ProBook 4321s Notebook PC
HP ProBook 4420s Notebook PC
HP ProBook 4421s Notebook PC
OPERATING SYSTEM(S):
Microsoft Windows 7 Home Basic 32 Edition
Microsoft Windows 7 Home Premium 32 Edition
Microsoft Windows 7 Professional 32 Edition
Microsoft Windows 7 Professional 64 Edition
Microsoft Windows 7 Starter 32 Edition
Microsoft Windows Vista Business 32 Edition
Microsoft Windows Vista Business 64 Edition
Microsoft Windows Vista Home Basic 32 Edition
Microsoft Windows XP Professional
RedFlag Linux
SuSE Linux
修正:
- Fixes an issue where fingerprint authentication is not required at the pre-boot level when logging into Microsoft Windows with all three credentials required. (When working correctly, the correct order for authentication is that fingerprints should be required AFTER entering the password, and then a Java card would be required as the last credential.)
游客,如果您要查看本帖隐藏内容请回复
.双击运行按照屏幕提示运行即可
.刷新BIOS需注意:
1.连接外接电源适配器与电池,使电脑处于稳定供电的状态。
2.刷新的过程中,后台不要运行其他应用程序。
3.刷新的过程中,不要异常中断。
4.BIOS刷新后建议恢复BIOS默认值。
GMT+8, 2025-5-13 11:27 , Processed in 0.078125 second(s), 26 queries .
